Ringfield Based HST Loco
ColinB
I have just converted my old Hornby HST to DCC. I have had it a long time and I cannot remember how well it ran. It runs ok, but struggles with more than one carriage. I have changed the traction types and added a bit of weight to the rear of the carriage with the motor in and updated the wheels on the carriages. It runs OK, but not very fast. Do these ringfield motors ever need remagnatising? Could it also be that the armature has lost a few windings? I noticed from the service sheets Hornby modified the design in line with that of Bachmann DMUs, which run really well (I have 170 DMU). So is it that the Ringfield design was never that good?
Why do you think it's the magnet - is it running slowly?
There have been several threads relating to maintenance of the same-type ringfield motor recently - last 2 weeks - I would suggest having a look at them.
Ringfield-powered HST's with tyres run and pull well from what I can make out, without modification.
Al.
Ringfields magnets can fade. I replaced one of mine (circular) with a neo and it was much improved, but the one with twin arch shaped magnets would not run well with neos so I opted for a new housing (H10) complete with new magnet.
Edit - I also tried twin motoring a 56 but that was a failure due to difficulty synchronising the motors, one would kick off before the other dragging the second one with locked wheels until that one kicked in and off it went like a rocket. That was reverted to a single motor.
Swapping to DVD motors works OK if you can’t or don’t want to refurb your ringfield.
 With the Ringfield armature it's worth having a look, as they can often be repaired. The commonest fault is the solder joints fail and go open circuit. The Ringfield is wired as a "Star" so underneath the commutator, you will find a joint where the three winding ends are soldered together. The other end of each wire is then soldered to a tab on the edge of each copper plate on the commutator. The commonest fault I have come across is these joints on the edge of the plate fail, but can be easily repaired by positioning the end of the wire back onto the tab and using a soldering iron to remake the joint. I bought a bag of about 30 of these off e-bay a few years back, which were all open circuit on a winding and got 25 working again, and almost all were exactly this problem. Repaired a few more since then with the same issue.
Thanks James, you were absolutely right. The wire looked to be attached to the commutator but when I melted the solder it fell away, so I suspect it was attached but not making connection. I have resoldered it and now I have three working coils. I will try it back in the loco. Very, useful information, thanks.
