Mac999 Posted December 11, 2019 Share Posted December 11, 2019 How do you remove the wheels off a standard scalexric car? 😮 Link to comment Share on other sites More sharing options...
woodcote Posted December 11, 2019 Share Posted December 11, 2019 Very gently! The ends of the axles are gnurled (ie raised and roughed-up) so twisting will remove plastic from the wheels. Pulling the wheels straight off is tricky and with excessive forced can crack the hubs. If I need to remove the wheels (a very rare thing...) I twist slightly and then pull. A drop of superglue on the wheel should hold the wheel tight when you push it back on. And make sure the wheel is absolutely straight on the axle. Link to comment Share on other sites More sharing options...
