Invincible Posted March 3, 2012 Share Posted March 3, 2012 I'm having trouble with setting up passing loops in Railmaster. I have a typical passing loop where points face eachother so to pass through the loop, both points have to be set curved. I've set them up with different accessory decoders but with the same number as my loops are quite long and I didn't want long wires. It works fine with the Elite but I can't work out how to program in RM. When I set it up on the layout designer, if I click one point, on the diagram it turns the opposite point the wrong way, so one is curved, the other is straight, and vice versa. I just can't get them to both show straight or both show curve. It's driving me mad! Link to comment Share on other sites More sharing options...
OldManOfSteam Posted March 4, 2012 Share Posted March 4, 2012 Hi Invincible, Just to confirm the exact problem you are struggling with, is it just that Railmaster is showing the two points opposing one another but the real points are doing what you want them to do which is both switching to the loop together when needed? Secondly, are you likely to want to switch the two points independant of each other or will they always be either both on main or both on loop? Dependent on your reply there is a solution to your problem Link to comment Share on other sites More sharing options...
Mike_G Posted March 5, 2012 Share Posted March 5, 2012 Hi allIf you have them both connected to the same decoder out let you can not switch them independant anywayi have had this problem as well and what i do is only put 1 red/green button on railmaster leave the other one blankwhen you install them just check witch way they turnmake sure the one with the flesh showes correctand if nessasary change the wires on the other so it turns correctthen both will turn into the passing loop with one mouse click on the one with the buttonsi tried all other ways and this is the only way it will work in railmasterMike Link to comment Share on other sites More sharing options...
Mike_G Posted March 5, 2012 Share Posted March 5, 2012 Mike_G said:Hi allIf you have them both connected to the same decoder out let you can not switch them independant anywayi have had this problem as well and what i do is only put 1 red/green button on railmaster leave the other one blankwhen you install them just check witch way they turnmake sure the one with the flesh showes correctand if nessasary change the wires on the other so it turns correctthen both will turn into the passing loop with one mouse click on the one with the buttonsi tried all other ways and this is the only way it will work in railmasterMikepsif you have them on separate decoder out putsand then set them as a route group it will work okjust thought i would add that before someone comes in and says i was wrongmike Link to comment Share on other sites More sharing options...
OldManOfSteam Posted March 5, 2012 Share Posted March 5, 2012 Hi Mike_G Rather than having a "blank" point it is perfectly possible to have a "phantom" point number which can be linked to the real point in the address list and can be made to show the correct position at all times, I have a number of these on one of my Railmaster diagrams and it works perfectly, just remember to give the phantom point a sufficiently high address that you are never likely to actually use.Mike Link to comment Share on other sites More sharing options...
Mike_G Posted March 9, 2012 Share Posted March 9, 2012 HiI will have to try thatcant at moment, am away at work ( 10 weeksof no trains )not exactly true cos i have Trainz on my laptopMike Link to comment Share on other sites More sharing options...
