stevecamden Posted June 22, 2011 Posted June 22, 2011 Some advice required....I want to connect a 2nd to 3rd radius using 2 Hornby curved points. Do I have to cut a bit of flextrack to link the two points? I know this sounds straightforward but I can't 'make it happen' with standard track bits.
Gregd99 Posted June 22, 2011 Posted June 22, 2011 Steve,I have never done this so my suggestion is a theoretical one.From looking at the track geometry document (https://www.hornby.com/_assets/files/Track-Geometry-PDF.pdf) it looks to me as though a "Half Curve 2nd Radius, R643" might do the job.I use a free piece of software called winrail to plan my layout. I am not sure if it includes the curved points.....Greg
stevecamden Posted June 23, 2011 Author Posted June 23, 2011 Gregd99 said:Steve,I have never done this so my suggestion is a theoretical one.From looking at the track geometry document (https://www.hornby.com/_assets/files/Track-Geometry-PDF.pdf) it looks to me as though a "Half Curve 2nd Radius, R643" might do the job.I use a free piece of software called winrail to plan my layout. I am not sure if it includes the curved points.....Greg
stevecamden Posted June 23, 2011 Author Posted June 23, 2011 Thanks GregIt's not the R643 - I have tried that one. The only problem with little bits of curved flex-track is getting it perfect as its a bit fiddly ( well I find it so)So I could just change the layout in that part so that both tracks are 2nd radius and use the R643 to make up the connections. And then widen it again after a straight.The other option, that I haven't tried, as I don't have the track is, from left to right:Outer curve: R608, R610,R8075,R609,R600 ( goes to parrallel straight.Inner curve: R606,R607,R8074,R643,R643 (goes to parrallel)Anyway -its not a big deal, but if anyone has done it elegantly then please let me know.Steve
FinnerZ Posted June 23, 2011 Posted June 23, 2011 Having done this in my own layout and Hornby virtual railway, I understand your problem and only found it in an ancient track plan book. This is how you were to do it in a 90 degree turn running from 6 o'clock to 9 o'clock, with the points running from 6 o'clock on the outer track to 9 o'clock on the inner track. You can simply flip it if you have a different curve layout. The outer loop (3rd radius) running from 6-9 is: R606, R8075(long side pointing inwards, loop continuing on shorter side), R607, and R610. The inner curve (2nd radius) from 6-9 is: R643, R607, R8074 (this connects to the longer part of cuved point. The points are connected by the R643. I will try and get a picture hosting account so I can post a diagram I've made of it. Please ask if I've been unclear, but this is the correct way to do it.
stevecamden Posted June 23, 2011 Author Posted June 23, 2011 FinnerZ said:Having done this in my own layout and Hornby virtual railway, I understand your problem and only found it in an ancient track plan book. This is how you were to do it in a 90 degree turn running from 6 o'clock to 9 o'clock, with the points running from 6 o'clock on the outer track to 9 o'clock on the inner track. You can simply flip it if you have a different curve layout. The outer loop (3rd radius) running from 6-9 is: R606, R8075(long side pointing inwards, loop continuing on shorter side), R607, and R610. The inner curve (2nd radius) from 6-9 is: R643, R607, R8074 (this connects to the longer part of cuved point. The points are connected by the R643. I will try and get a picture hosting account so I can post a diagram I've made of it. Please ask if I've been unclear, but this is the correct way to do it.
stevecamden Posted June 23, 2011 Author Posted June 23, 2011 Thanks - actually I had just deduced this one myself - Interesting that yo can't go from 2nd radius R607 to 3rd radius arc R609?The R643 is too small to join the two points - almost looks like you need a 3rd radius half curve which doesn't exist ( hence my question originally about using a flex-track piece.Now I don't know if it is me but the parrallel end R610 ( 3rd radius) and R8074 seem a bit distorted as if it is pulling it in a bit. I just wonder if in time this will cause derailments.You do need to build these things sometimes - seeing it on paper or screen doesn't show if it pulls or is too tight etc.If you look at the hornby trackplan they show a 2nd to 3rd connect with a joiner track piece un-identified. This is the bit that looks to me like a 3rd radius half curve.I wonder if hornby could clarify....
FinnerZ Posted June 23, 2011 Posted June 23, 2011 It is a bit distorted but it doesn't cause derailments - I've been using my set up for years and I get more derailments on straight points. I'm not sure why your R643 doesn't work because it fits mine. Are you certan that the ends of the curves are the exact 67 mm apart because this could be your problem. I'm afraid I don't understant your first point about going from 2nd radius R607 to 3rd radius arc R609.
stevecamden Posted June 23, 2011 Author Posted June 23, 2011 FinnerZ said:It is a bit distorted but it doesn't cause derailments - I've been using my set up for years and I get more derailments on straight points. I'm not sure why your R643 doesn't work because it fits mine. Are you certan that the ends of the curves are the exact 67 mm apart because this could be your problem. I'm afraid I don't understant your first point about going from 2nd radius R607 to 3rd radius arc R609.
stevecamden Posted June 23, 2011 Author Posted June 23, 2011 Sorry the R643 does fit - Its just that as you say its a bit 'tight' even with a bit of pushing and pulling.What I mean't was, if you look at the hornby trackplan it shows the curved points going from 2nd to 3rd radius using the R609 with a bit of track between the points ( the connector) that isn't a R643. My question is - what is this bit of track?
Big Gordon Posted June 24, 2011 Posted June 24, 2011 Funny I was having exactly the same problem, but found the answer in the current (R8140) Track Plan book page 40. R 643 is indeed the joiner, but as you say a bit tight.
Class421 Posted June 24, 2011 Posted June 24, 2011 180 degree turnOuter Track: R610 - R607 - R8075 - R607 - R8074 - R607 - R610Inner Track: R8074 - R607 - R606 - R607 - R8075In-between the points is a R643. I have used this setup on my last 2 layouts, as detailed on the relevant track plans and have had no problems
stevecamden Posted June 25, 2011 Author Posted June 25, 2011 Yes I concur! It is the R643, and I have used the R608 before the curved point on the outer track as this seems to smooth the transition a bit better when the loco is crossing - I had had derailements with the R607. I think its because the R643 in between the points ( slight distortion) isn't exactly right but anyway I have tested in all directions and I am happy.Well I never was any good at geometry at school....
Akerbill Posted May 4, 2020 Posted May 4, 2020 180 degree turnOuter Track: R610 - R607 - R8075 - R607 - R8074 - R607 - R610Inner Track: R8074 - R607 - R606 - R607 - R8075In-between the points is a R643. I have used this setup on my last 2 layouts, as detailed on the relevant track plans and have had no problems Thank you very much. I got this from Hattons and trust it's OK to post it
Chrissaf Posted May 7, 2020 Posted May 7, 2020 Ackerbill, Your image failed to upload. . This forum does not support 'Cut n Paste' nor 'Drag n Drop' of images. You have to use the 'image uploader tool'. . See TIP 8 in my 'How to use this forum' page linked further below: . However, that said. It really isn't worthwhile resurrecting a thread that is 9 years old. The information in a 9 year old post will be well out of date by now. If your image is this one below or similar, then it has already been posted on this forum many times in much later threads than this one. . . . TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button. . Particularly as my reply includes an image, using the 'Blue Button' may result in your reply being held back for image approval, even though it is an existing image. . See also – further TIPs on how to get the best user experience from this forum. https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/ .
