IJG Posted January 2, 2020 Share Posted January 2, 2020 Morning and a happy new year to all.I know I have seen this subject before but for the life of me I can't find it so I apologise for starting it anew.Following a computer crash, I have had to reload Railmaster and all its updates to Version 1.72. I have solved the lack of communication between railmaster and elink following the advice of members on this forum and that is working fine but I cannt solve the lack of a short circuit message. I am having to exit then restart railmaster to solve this.Could some one kindly post the fix please. I am running Railmaster on a windows 8 PC Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted January 2, 2020 Share Posted January 2, 2020 Ensure the line "Check controller=1" is present in your RailMaster.ini file, which you can edit by clicking on the small cog icon in the Help window in RailMaster. Link to comment Share on other sites More sharing options...
IJG Posted January 2, 2020 Author Share Posted January 2, 2020 That line is present. From memory it was one I had to change to get the elink to work but I may be wrong Link to comment Share on other sites More sharing options...
PogiPete Posted June 9, 2020 Share Posted June 9, 2020 Hi Did this ever get resolved? I have put "Check controller = 1" and still don't get a message. Is there a quick way to reset when using eLink?Many thanks Link to comment Share on other sites More sharing options...
Chrissaf Posted June 9, 2020 Share Posted June 9, 2020 Follow the instructions EXACTLY as written in my reply to this similar posted question [specifically the bit about deleting and retyping the entries at the end of the file].https://www.hornby.com/uk-en/forum/short-circuit-recovery/?p=1.Although not mentioned in the linked post above, given that you are using 1.72 I would also take the opportunity to change 'Reset eLink on start' from =1 to =0 if it is still =1. Link to comment Share on other sites More sharing options...
