Pedroski Posted February 1, 2020 Share Posted February 1, 2020 I have a Lord Nelson and Flying Scotsman, both TTS versions from Hornby. My problem is that I have set the speeds for cruise and shunt at set values, but the vertical throttle on RailMaster shows a maximum speed of 1. The locos will move, but only at top speed, much too fast for my track. I cannot slow them down. Link to comment Share on other sites More sharing options...
Chrissaf Posted February 1, 2020 Share Posted February 1, 2020 This has come up before. Others have found that completely deleting the loco from the RM loco roster and then reloading it and setting it up afresh from scratch has usually cured the issue..If you are not 100% sure of the correct process to set up a TTS loco then review this previous posted thread.https://www.hornby.com/uk-en/forum/how-to-set-up-default-sound-functions-on-scotsman-r3284tts/?p=1and this onehttps://www.hornby.com/uk-en/forum/changing-cruise-and-shunt-speeds/?p=1.TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
