Tigerrider Posted February 12, 2020 Share Posted February 12, 2020 Hi, does anyone know if there is a way to access function numbers 21 onwards on a TTS decoder when using Dynamis EZ Command? Link to comment Share on other sites More sharing options...
Chrissaf Posted February 12, 2020 Share Posted February 12, 2020 The Dynamis only supports up to F20 [a total of 21 functions F0 to F20] - see manual extract below..If Bachmann have not updated the Dynamis firmware to access F21 to F28 then there is nothing you can do. The TTS decoder does not support any form of Function Mapping. Contact Bachmann direct and ask them if there is a firmware upgrade for the Dynamis../media/tinymce_upload/c2f9c9f8e1b3b6815c7011779b801cdd.jpg.TIP: As this is your very first post, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..Particularly as my reply includes an image. If you use the blue button, any reply you write, may be held back for image approval. Even though it is already a previously published image..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
Tigerrider Posted October 16, 2020 Author Share Posted October 16, 2020 Hi Chrissaf,Thanks for your reply. I suspected that would be the case.I have to admit that I forgot that I had posted this query but I do appreciate your response. Thanks again.Ian. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 16, 2020 Share Posted October 16, 2020 You had forgot ... not as much as I had forgotten.Oh well ... I suppose better late than never. What was the end result? did you get the issue resolved? I'll diary June 2021 to look for your reply 😉 Link to comment Share on other sites More sharing options...
