Peter E Posted March 6, 2020 Share Posted March 6, 2020 Hi,I recently bought a second hand C2919 Morris Mini which looks great after a clean up. However, on running it was making a terrible clicking sound. I opened the car up and it appears that the contrate gear has split. This looks to be a 20t gear but I was not sure what type of replace it with. I have taken apart the axle and removed the gear OK so I should just be able to slide on a new one. Could anyone suggest the best replacement match to this gear? Link to comment Share on other sites More sharing options...
woodcote Posted March 6, 2020 Share Posted March 6, 2020 Hi Peter E - welcome to the forum! To help with finding spares, there are service sheets for some cars on this website. The one for your Mini is here: https://www.scalextric.com/uk-en/catalogsearch/result/?q=C2919#product_tabs_servicesheets_contents The direct replacement for the rear axle assembly is W9861. I don't see any available online. All the other axles on that sheet will fit your car, but the wheels might not be the correct style. Maybe you could search for those? I am pretty sure the gear is smaller than the standard Scalextric inline gear, so you won't be able to replace the split gear with a new Scalextric one. I hope that helps. Link to comment Share on other sites More sharing options...
Peter E Posted March 6, 2020 Author Share Posted March 6, 2020 Thanks for the information, I will do some searching!Yes, you are right the contrate gear is pretty small compared to some of my other cars like a BTCC BMW 125. Link to comment Share on other sites More sharing options...
