Dwarfboysim Posted March 21, 2012 Share Posted March 21, 2012 Hi all,I have created my layout on Rail Master and I am in the process of configuring the points. For my passing loops where both sets of points need to be set as curved or straight at the same time I have attached both sets of points to the same port on the accessory and point decoder so they use the same ID. This works well and flicks the points correctly on the Elite. However on the Rail Master screen it shows one set of points to be set straight and the other end curved each time I throw the points via RailMaster even though both have thrown correctly on the actual layout. Is there away to make Rail Master show both sets as curved when they are set to curved.I have based my layout on Track Plan 9 from the Hornby Track Plan book. See my blog at: <a href="http://tinyurl.com/DwarfboysimBlog">http://tinyurl.com/DwarfboysimBlog</a> showing some pictures of how my layout is constructed if that helps. Any advice or tips greatfully received.Thanks,Dwarfboysim Link to comment Share on other sites More sharing options...
captaincookie Posted April 2, 2012 Share Posted April 2, 2012 Hello DwarfboysimYou might need to set them on the same route, if you go to the design screen and select one of the points then make a route called "straight" and set the point to the straight position i.e. green, then make one for "switch" and do the same , i.e. set colour red, then go to the other set of points and do the same using the smae names which will appear in a drop down menu, this will then enable railmaster to show both states but you need to run the chosen route to get it to register the correct setting on railmaster ( not by clicking the red/ green buttons)Hope this is helpful.Ian Link to comment Share on other sites More sharing options...
Mike_G Posted April 4, 2012 Share Posted April 4, 2012 captaincookie said:Dont think you will find that will workas both points are connected to the same decoder output railmaster only sees left/right never mind what hand the point isi have the same problemin the end as my passing loops are 1 way i just left the red//green buttons off the exit endin railmaster, its a bind i know but as long as they switch correct no problemMikeHello DwarfboysimYou might need to set them on the same route, if you go to the design screen and select one of the points then make a route called "straight" and set the point to the straight position i.e. green, then make one for "switch" and do the same , i.e. set colour red, then go to the other set of points and do the same using the smae names which will appear in a drop down menu, this will then enable railmaster to show both states but you need to run the chosen route to get it to register the correct setting on railmaster ( not by clicking the red/ green buttons)Hope this is helpful.Ian Link to comment Share on other sites More sharing options...
