otisman Posted March 18, 2020 Share Posted March 18, 2020 The display section for speed control is not showing the level.see image. Notice how green bar has no speed indicator on it.Do I re load program from disc/internet or is there a problem with unit./media/tinymce_upload/6ef1eeed29a76f2d8c71ac4bf2c18004.jpg Link to comment Share on other sites More sharing options...
Chrissaf Posted March 18, 2020 Share Posted March 18, 2020 These sort of speed display issues have come up before. The usual fix has been the remove the loco completely from the RailMaster loco throttle roster and re-load the loco into RM from scratch..To ensure that you are loading the loco into the RM throttle roster correctly, then review these previous 'How To' threads. Not every thread below will be specifically relevant to your loco, but taking them all together will give a good overview of most loco type scenarios..Adding a loco from the database into RM.http://www.hornby.com/uk-en/forum/loco-registration/?p=1.Using RM to read and write CVshttps://www.hornby.com/uk-en/forum/problem-with-tts-decoder/?p=1.Manually adding a Loco to the RM Database.https://www.hornby.com/uk-en/forum/r3459tts-decoder-not-recognized-23469/.Full description of the ‘Locomotive Settings’ screen in detail.https://www.hornby.com/uk-en/forum/changing-cruise-and-shunt-speeds/?p=1.Setting up Flying Scotsman TTS Sound Functions.http://www.hornby.com/uk-en/forum/how-to-set-up-default-sound-functions-on-scotsman-r3284tts/?p=1.TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 18, 2020 Share Posted March 18, 2020 Do make sure you are using the latest RM version by downloading from the link at the top of the forum and running over the top of the existing installation. It is not necessary to uninstall your existing version first. It is worth doing this regularly as HRMS make all manner of changes, usually minor, that don't invoke the auto update function in RM. Some actually run in the background when you start RM But no harm in installing them again. Link to comment Share on other sites More sharing options...
