Andy 333 Posted March 29, 2020 Share Posted March 29, 2020 I have bought GWR HST train set dcc ready bought Hornby class43 valenta sound decoder installed this myself having previously installed sound to a class 47 successfully. Sound works fine but when moving train takes mind of its own and cannot be stopped I have hornby select controller . Have tried resetting a number of times but still the same .any ideas please Andy Link to comment Share on other sites More sharing options...
96RAF Posted March 29, 2020 Share Posted March 29, 2020 Do you have DC running turned on i.e. will the motor run if you apply a PP3 9volt battery to the wheels.If so you need to turn it off in CV29 but you can only do this if your Select is at firmware v1.6 or higher. Watch the screen at startup for xx thrn 30 then 03. xx needs to be 16. Link to comment Share on other sites More sharing options...
ColinB Posted March 29, 2020 Share Posted March 29, 2020 The first thing to do is to figure out if there is something wrong with the decoder. If it is easy, take the decoder out of the GWR HST and try it in the class 47. If it works in the class 47, then there is something wrong with the GWR HST. What you can also do if you have a multimeter is check the resistance between the pins on the 8 pin connector in the GWR HST. THey should all read high resistance except between pins 1 and 5. Whatever you do don't try the class 47 decoder in the GWR HST, just in case it is damaging them. Other than wrong wiring of the 8 pin socket, the only other thing I can think of is the capacitor across the motor causing issues. I have had "run away" with some LaisDCC modules with bad track (sometimes the loco even goes backwards), but Hornby ones are usually ok. I fitted the HST TTS decoder to my ringfield based HST with no issues, generally if it is dirty track the decoder sound usually just keeps resetting. Link to comment Share on other sites More sharing options...
Chrissaf Posted March 30, 2020 Share Posted March 30, 2020 Andy,I have removed your failed attempt to reply using the 'Blue Button'. The blue button is not a 'Reply to this post button'. There is no 'Reply' button embedded in each individual post on this forum. See below with regard 'how to reply':.TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
jane1707819582 Posted March 30, 2020 Share Posted March 30, 2020 Give your track a very good clean.The select controller does this a lot. Link to comment Share on other sites More sharing options...
Andy 333 Posted March 30, 2020 Author Share Posted March 30, 2020 Thank you for replies and suggestions The train does not run when connected to dc supply i think decoder ok as I bought pair (unfortunatly dummy car not got DCC plug) I have tried second decoder same thing happens.I think I may wait post virus and get it checked out by local DCC specialist. My select controller is good 5 years old I bought secondhand so this may need upgrade to new one which may help. Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 30, 2020 Share Posted March 30, 2020 A couple of things that might help Andy: First, is it possible you have a DC power track or power connector between the Select and the track. Check them by flipping open the black housing and see if there is a component (capacitor) in there. If so remove, and make sure you remove any and all. These distort the DCC signal giving weird effects and sometimes only on particular decoders. You should definitely get your Select firmware upgraded to v1.6 so you can change CVs. Ring Customer Care to get details. When you get it back, try changing the motor algorithm CV150 from 0 to 1 and see if that improves things. Link to comment Share on other sites More sharing options...
