Benatkinsonuk Posted April 14, 2020 Share Posted April 14, 2020 Hi, due to lockdown I've got back into modelling and I must say it's been superb fun. And the bug has bitten me! So apologies if this isn't in the right place. I have read the forum a bit and can't find an exact answer.I will be painting the model with acrylics, then glossing with humbrol clear, decaling with decal fix, then I had hoped to use acrylic Matt spray varnish. Though I have read some issues with this? I tested on an old model today and it worked on the (enamel) paint, but pitted some decals (I hadn't used a decal fixer back then!). Should I continue with my plan or use a different Matt varnish? I do have a bottle of Matt coat I could use or buy something else? Thanks again , Ben Link to comment Share on other sites More sharing options...
Mtchllro Posted April 14, 2020 Share Posted April 14, 2020 Personally I gloss over decals when they are fixed in place to seal in decals and then use a Matt varnish over that.I use pledge multisurface wax (formally Future) both under and over decals Link to comment Share on other sites More sharing options...
Mtchllro Posted April 14, 2020 Share Posted April 14, 2020 Doh that should say "(formally Klear)" not future .sorry Link to comment Share on other sites More sharing options...
Benatkinsonuk Posted April 14, 2020 Author Share Posted April 14, 2020 Personally I gloss over decals when they are fixed in place to seal in decals and then use a Matt varnish over that.I use pledge multisurface wax (formally Future) both under and over decalsHey thanks for the reply :) I will year that method - i can gloss over the old models decals then Matt varnish it. Link to comment Share on other sites More sharing options...
peebeep Posted April 14, 2020 Share Posted April 14, 2020 Decals work best on a glossy surface, although if you look up the Decalfix video on Youtube decaling onto a matt surface is demonstrated. Personally I prefer to gloss before decaling, because it's always worked for me and I know it should eliminate any chance of silvering. I have a theory about the aerosol varnishes that involve a hot solvent in the propellant. I may well be wrong, but if I'm not it would explain a lot of the problems people have with them. Link to comment Share on other sites More sharing options...
