New R8249
kingedward2..Andy
Try not to confuse decoder functions with controller functions.
Purple is decoder function four but switched by F2 on a controller.
Decoder functions one and two are switched by controller F0 and used for directional lighting - white and yellow wires in conjunction with common blue.
Decoder function three is switched by controller F1 and can be used for an auxilliary purpose - green wire in conjunction with coomon blue.
R8249 is a four function decoder and does not support controller F3 and F4, which are only seen on six function decoders.
Make sure you insulate it, nail varnish seems to work ok. I have blown a couple of DCC decoder up where this stray wire accidently touches the chassis while you are fitting the decoder into the body (trouble is it moves around as you fit the body) .The only thing you know is when you first run the loco and you get a buzz and the decoder doesn't work anymore. Some people platt it into the decoder wiring harness. I also cover the decoder with a sleeve of heatshrink that isn't heatshrinked, so that air can flow through it, but provides insulation. If you are into computers they are really "open collector output ports", the function is really what controls them, but all the DCC decoder manufactures call them functions.
