tradie Posted April 18, 2020 Share Posted April 18, 2020 i am trying to remove the motor out of the tneder chssis of henry so can see the wheel problem, just doesnt seem to want to come out. there is, what looks like, a plastic part going into the chssisabove the tow pin, but i cannot seem to a) remove it b) how it comes out.Any help please ? Link to comment Share on other sites More sharing options...
Modelnut19 Posted April 18, 2020 Share Posted April 18, 2020 If it is a tender drive then I think you will find the motor section can be carefully prised out of the tender chassis using a screwdriver at each end of the chassis. However, I should check for some guidance on YouTube first. Link to comment Share on other sites More sharing options...
tradie Posted April 18, 2020 Author Share Posted April 18, 2020 If it is a tender drive then I think you will find the motor section can be carefully prised out of the tender chassis using a screwdriver at each end of the chassis. However, I should check for some guidance on YouTube first. ive looked and its not on you tube or sim it is that clip that goes into the chassis above the tow pin needs to either be moved or taken out im not sure it doesnt want to budge any more prising i will bend the chassis Link to comment Share on other sites More sharing options...
Chrissaf Posted April 18, 2020 Share Posted April 18, 2020 TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
96RAF Posted April 18, 2020 Share Posted April 18, 2020 You need to prise the arrowed lug away from the tender frame. It is similar at the other end. You may need to remove Items 18 for access to it.Service sheet 258/media/tinymce_upload/7158db1a26b858d18393c3979f2a4920.png Link to comment Share on other sites More sharing options...
