Trains trains trains Posted April 25, 2020 Posted April 25, 2020 Hello, I recently purchassed Triang R355 Nellie. After a good service and clean, the locomotive will run however, when I got it running, it wobbled and shortly followed the connecting rods on one side went diagonal, therefore couldn't run any more. After I looked at the wheels it looks like they weren't factory quartered propably as they are not off set by 90 degrees. Any help would be appreciated.
Stubaggieboy Posted April 25, 2020 Posted April 25, 2020 There are insulated plastic bushes on one side of the axles the side where the pick up wipers are that have either split or worn and will require replacing. I purchased some of these bushes a while back from Ebay so they are probably still available. Then obviously you will need to quarter the wheels correctly. Hope this helps. Regards Stu.
Chrissaf Posted April 25, 2020 Posted April 25, 2020 TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/.
Ruffnut Thorston Posted April 25, 2020 Posted April 25, 2020 There are two sizes of the plastic wheel bush. The later version S.8397 is smaller, as the axles are of a smaller diameter where they are inside the wheels. /media/tinymce_upload/735282864fdcfbe49c7927ded87fd2a7.jpgThe rest of the later axles is if the same diameter as the earlier axles.S.5065 will likely be the correct size for the R.355 locos. /media/tinymce_upload/bd3bbb829790e2f6eb5af70b5ea87600.jpg/media/tinymce_upload/629978660caa16f0e8fb238ffe0956f8.jpg http://www.hornbyguide.com/item_details.asp?itemid=483
Rana Temporia Posted April 25, 2020 Posted April 25, 2020 The wheel bushes are available from Peter's spares (and off them on eBay) as one of their new manufactured parts. Also to check, if yours is one of the later models with a black plastic cog they tend to come loose on the axle. I have replaced mine with brass cogs from scrap locos. Another issue with this loco is that the tyres occasionally come off the wheel hubs easily.
Trains trains trains Posted May 2, 2020 Author Posted May 2, 2020 hello, thank you all for your help, very appreciative and got the problem fixed
