Phil G N Posted April 30, 2020 Share Posted April 30, 2020 Hi.Ive Just purchased a select controller and was hoping it came with the latest firmware1.6 but on booting up the number starts 20 30 03 can anybody confirm if it is the very latest firmware, i cant find any info relating to firmware above 1.6. Thanks just stepping up to the world of dcc. Link to comment Share on other sites More sharing options...
Chrissaf Posted April 30, 2020 Share Posted April 30, 2020 Firmware 1.6 and firmware 2.0 are one and the same. In essence, your Select showing 20 [2.0] on boot up is indeed as good as 16 [1.6]..Why does the Select show 20 and not 16, you ask..The Select hardware has had a very slight appearance revamp in this latest factory production run. Hornby have decided to name the firmware in this new revamped Select as 20 rather than 16 so that it then indicates that the Select is the latest new physical model. Thus it is actually better than the Select 16 model you were hoping for..As a result of the above statement, all documentation that relates to version 1.6 is applicable to version 2.0 too..If you go to the Select Manual download page, you will find this statement (highlighted in yellow below)../media/tinymce_upload/20ed8e0581f2d584163a5536fa9a406f.jpg.TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..Particularly as my reply includes an image, using the 'Blue Button' may result in your reply being held back for image approval, even though it is an existing image..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
Phil G N Posted April 30, 2020 Author Share Posted April 30, 2020 Thank you for answering the query you've explained it perfectly, that explains why the 1.6 addendum leaflet came with it. Link to comment Share on other sites More sharing options...
