david_coxon Posted May 2, 2020 Share Posted May 2, 2020 Hello I have a Hornby Class 66 with TTS fitted at first the sound worked now it has stop, the loco still runs. I am using a Select controller which has been upgraded by Hornby to 1.6. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 2, 2020 Share Posted May 2, 2020 About a 95% probability that either the 'speaker' has blown ... an extremely common issue..OR the Audio Amp on the decoder has blown ... a common issue but not as common as the speaker..If it's under Warranty send it back. If outside Warranty the cheaper initial option is to replace the 'speaker' with a non Hornby branded one that will be more reliable .. this speaker must be not less than 8 ohms rated. If that doesn't work, then the decoder will need 'repair / replacing'..By the way ... you never gave a follow up reply to your other post .. follow this link:https://www.hornby.com/uk-en/forum/surface-point-motors-not-working/?p=1/#post-328128.TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
Flashbang Posted May 2, 2020 Share Posted May 2, 2020 HiAssume you have turned the sounds On via F1 (Function 1)?? Link to comment Share on other sites More sharing options...
