null_null981707818191 Posted May 3, 2020 Share Posted May 3, 2020 A few people made some kind comments about my previous post (the Avro Anson), so I thought I'd risk another one... this time of the Airfix 1/72 Bf109-G-6. Modelled very much OOB, although I did manage to cut the canopy up with a razor saw so that I could have it open. The reason that I wanted to do this one was to try to see if I could replicate blotch-camouflage using brushes (I don't have an air-brush) - I'm reasonably pleased with the result, so will now be encouraged to try it again on the Bf109E that is sitting on the shelf waiting to be built. I enjoyed the build!I've included a few pict/media/tinymce_upload/d73e21e81576fc1dd9bc7f8792add8a9.jpg/media/tinymce_upload/357f6ea78359639ce800678278a601c0.jpg/media/tinymce_upload/9dadc0b5adbbcf9c90faee2f4194fda2.jpgures...And as an add-on, if anyone can tell me how I can change the name that appears with my posts, I'd be grateful! For some reason, this Forum has decided that my name is null-null98. I've e-mailed airfix@ but no reply... So if the moderator is able to effect the change for me, I'd like my name to appear as Landy Link to comment Share on other sites More sharing options...
Dark Earth Posted May 8, 2020 Share Posted May 8, 2020 A nice job with the brush painted mottling Landy ! Love the extra work put into opening the canopy too. Quality work there.Chris Link to comment Share on other sites More sharing options...
T2B Posted May 8, 2020 Share Posted May 8, 2020 Yes that's very good Landy. If you don't want such a heavy mottling effect try less paint on your brush. When I used to use hairy sticks I took a fairly stiff brush and cut the bristles so you have a hard flat surface for stippling. But I like what you have done with the canopy and seatbelts for the pilot! Link to comment Share on other sites More sharing options...
Tweezers Posted May 10, 2020 Share Posted May 10, 2020 Very good!Any tips for improving the sparse cockpit? Link to comment Share on other sites More sharing options...
Peter s Posted May 11, 2020 Share Posted May 11, 2020 Very nice! Even with an airbrush the 109 is so tiny in 1/72 its easier said than done. Whats worked well for me in the past is to use a cotton bud (Q-tip in American). Blot it almost dry on paper (I use acrylic) then lightly apply the blots. The furry head gives a defuse blot if you're careful rather than a paint spot. Your pilot is so good no-one will notice the lack of cockpit detail either. He could be 1/48 easily. Link to comment Share on other sites More sharing options...
T2B Posted May 11, 2020 Share Posted May 11, 2020 Yes using a cotton bud similar to dry brushing should work well with care for mottling. I hadn't tried that before? And Tweezers, as Peter s says the pilot fills the cockpit void so we'll the lack of detail can't be noticed especially if the closed kit canopy is used! Link to comment Share on other sites More sharing options...
peebeep Posted May 11, 2020 Share Posted May 11, 2020 Airwaves PE detail set if you must, but as mentioned above if you use a crew figure it's a bit of a moot point. Link to comment Share on other sites More sharing options...
canbuster Posted May 11, 2020 Share Posted May 11, 2020 Although i am only just getting back into the hobby, i do have a airbrush, and did this same Model myself last month. Ihave to say your mottling is better than mine, its a nice build. Link to comment Share on other sites More sharing options...
peebeep Posted May 12, 2020 Share Posted May 12, 2020 This is the PE set I was referring to, available at Hannant's /media/tinymce_upload/208843fbe8c368950a9651a8b38e582d.png Link to comment Share on other sites More sharing options...
