Chrissaf Posted May 8, 2020 Share Posted May 8, 2020 If a loco derails even it one wheel the only way to start again is to power down eLink disconnect from RailMaster power and reconnect..The fix for this is detailed in this previous topic thread......follow link below after reviewing the next paragraph..Note on the linked page the little red oblong circled in the image. If you can see this red oblong then when you get your short, you remove the cause of the short and then click the red oblong to restart everything. If you can't see this red oblong, then follow the guidance in the link below to make it appear..For others reading. This software red oblong reset controller reset button only shows when using eLink. There is no red oblong reset button when using an Elite controller with RailMaster as the reset button is a physical button on the Elite itself..https://www.hornby.com/uk-en/forum/short-circuit-recovery/?p=1.TIP: As a relative newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 8, 2020 Share Posted May 8, 2020 hi can someone help me please.I am in the middile of contructing a layout using RailMaster and eLink. everything is ok until I have a derailment.if a loco derails even it one wheel the only way to start again is to power down eLink disconnect from RailMaster power and reconnect.advise on how to restart without having to go through the above welcome. eLike only 2 months old. Link to comment Share on other sites More sharing options...
