Big Alan Posted May 23, 2020 Share Posted May 23, 2020 Why did Hornby replace some of their Track Part Numbers? I think R600, R601, R603 have remained the same thoughout, yet R632 a 'Y' Point is now R8076 and I think that their are a few others. If the original number was a steel rail and the new number is Nickel Silver why not keep the old number with the addition of 'NS' after, as in, R632NS. I was looking at some plans in the 6th Edition of Track Plans and all these odd numbers have popped up, hence the question. And while I'm on it, whats the difference between R612 & R8072, R613 & R8073, all 168mm turnouts? Link to comment Share on other sites More sharing options...
JJ73 Posted May 23, 2020 Share Posted May 23, 2020 Hiya Well Track Plans is now on Edition 14!!!R600 = Straight TrackR601 = Double StraightR603 = Long StraightYes looks like R632 has changed to R8076 Also on the same topic - about same numbers being kept - have a read about my Colour Light Signls /media/tinymce_upload/756173ee1cb8cfeefaffddedf2e86472.JPG You can see why the number has changed - the design has also changed - The R612 is manual & the R8072 is manual / automatic (if you connected up to a Point Motor (R8014)) & the same for R613 & R8073. Once the design of the track change - they normally change the number aswell. R612 was made in Austria & R8072 is made in China. I have found that with my R612 - it still works - but not as good b/c with the 'centre rail'??? which it the bit which dirverts the Loco either left or straight on - it does not touch the outer rail very good - so the Loco stops - it's ok for use in sidings but not ok for use on the Main Line!!!If you take a look at my video - you will see why I had to change it... Link to comment Share on other sites More sharing options...
Big Alan Posted May 23, 2020 Author Share Posted May 23, 2020 Yes I know we are up to Edition 14, I have most of them going back to Edition 4 printed in 1976 Link to comment Share on other sites More sharing options...
