9F collector Posted May 24, 2020 Share Posted May 24, 2020 Hi GuysNeed a bit of advice have dismantled and cleaned a Western class 52 motor as it was running slow and after a couple it would speed up and run well .the next day it did the same again any advise how to sort this thanks Link to comment Share on other sites More sharing options...
Chrissaf Posted May 24, 2020 Share Posted May 24, 2020 Whilst you wait for a reply, perhaps you would spend a few minutes reviewing the TIPs in the TIP page link below:.TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
ColinB Posted May 24, 2020 Share Posted May 24, 2020 Check the motor brushes and springs and add some sparse lubrication. It might also be the pickups or wheels, after a couple of circuits any oxide that has formed on the pickups or wheels, which is a great insulator, gets cleaned off a bit. I don't know if this has the dreaded traction tyres, check that they are not slipping, again, once they warm up they seem to run better. Link to comment Share on other sites More sharing options...
