Lowey Posted May 31, 2020 Share Posted May 31, 2020 My class 66 keeps derailing on my points,all other loco's are fine.Would changing the wheels solve the problem? Link to comment Share on other sites More sharing options...
STG Posted May 31, 2020 Share Posted May 31, 2020 You need to reset the back-to-back wheel gauge (using a tool), not necessarily the wheels. Wheels from manufactures do not necessarily have the gauge correct Link to comment Share on other sites More sharing options...
Howbi Posted May 31, 2020 Share Posted May 31, 2020 First thing to try is to pin down the centre of the point because many have found the centre section to be slightly curved upwards..........HB/media/tinymce_upload/dd37f74216a930e4be14ebca95af814a.png Link to comment Share on other sites More sharing options...
ColinB Posted May 31, 2020 Share Posted May 31, 2020 I have had a lot of trouble with locos derailing at points. On my old ones it is the back to back wheel spacing. With the newer ones it is because the point is not level, has got distorted ( actually the base was bent) or there is an issue with the track entering or leaving the point. Leveling seems to be the biggest issue. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted June 1, 2020 Share Posted June 1, 2020 Lowey hasn't said which manufacturer his 66 is, or which radius point he is using.Bachmann 66's don't like 'standard' points, the bogeys can't turn far enough without getting stuck on the frames. Link to comment Share on other sites More sharing options...
96RAF Posted June 1, 2020 Share Posted June 1, 2020 Agreed - I had a derail problem at the top of a hill. Going ahead is sometimes the problem, but going to the diverging track was never a problem.The offending point has been pinned down as suggested and only the odd loco trips up here, so that will be getting the B2B inspection.Reposted to put all the previous typos right. Link to comment Share on other sites More sharing options...
