zcr2244 Posted April 10, 2012 Share Posted April 10, 2012 I have an older L gauge DC set that runs at 9V that I'm concerting to DCC with the Hornby DCC system that runs at 12V. I was wondering how to limit the voltage going to the motor so that I don't burn it out. I have experimenting with voltage regulators and they work but they are a little bit big. Has any one else tried doing this? PS I don't want to have to set the max running voltage with the DCC transformer as I just want to limit the power with extra components, in between the orange and gray inputs that direct power to the motor. Link to comment Share on other sites More sharing options...
Rog RJ Posted April 10, 2012 Share Posted April 10, 2012 You could try fitting a series of diodes (wired in inverse parallel to allow forward and reverse running) in series with the motor feeds. Each diode would drop about 0.5 volts each and the power dissipated is shared between the diodes.Inverse parallelOrange wire ____>>>>>>____ To motor terminalOrange wire ____ and < represents a diodeThe diodes could be inserted into either the orange or grey wires or even into both Link to comment Share on other sites More sharing options...
Rog RJ Posted April 10, 2012 Share Posted April 10, 2012 Oh dear, my little diagram failed to load properly but I think you probably know what I mean. Link to comment Share on other sites More sharing options...
Blackbird Posted April 13, 2012 Share Posted April 13, 2012 The DC output to the motor is controller by the DCC decoder. Although most motors are nominally 12V the DC output from the decoder is variable, 0-15v (approx). Most nominal 12v motors will run at around 15v max. The decoder can be programmed for maximum volts output (speed). So you can program decoder to give maximum to suit your loco's motor.CV5 will set the Max volts, 255 being max, then 190 will give (approx) 11.5v max, which should be suitable for your (nominal 9v) motor, or you can reduce CV setting to suit. Link to comment Share on other sites More sharing options...
