Chrise Posted June 13, 2020 Posted June 13, 2020 Does anyone know if third radius straight points are available from anywhere
LCDR Posted June 13, 2020 Posted June 13, 2020 No. your choices are Second Radius 438mm radius, or Express Points 852mm radius. Peco Streamline also make larger radii, but these are 2 feet radius (610mm), 3 feet radius (914mm) and 5 feet radius (1524mm). Third radius is 1 foot 10 1/2 inches (505mm)., so Peco 2 feet radius is close but not exact, and uses a different geometry. Hornby points turn out at 22.5 degrees Peco at approximately 12 degrees.
Howbi Posted June 13, 2020 Posted June 13, 2020 You can commission any design pointwork from Marcway Pointwork.net. .,......HB
