Loco address follow up.
geejbee
Good evening.
I posted sometime ago about my inability to get my new Tornado to accept an address and am awaiting Hornby to become operational again so that I can get my Select updated as advised.
However while just experimenting today, I put the Tornado on the track, and while the select was at default (03), away went the Tornado. So at least I know now that it goes. I did try setting a new address but without success. Now this probably sounds obvious to you people who know what you are doing but I thought I would share it anyway.  I thought I'd better check that it is ok to use the loco at the default address until such times I can get the select seen to.
You can use a loco on any address which the decoder accepts. You can use locomotives on 3, but since it is the default make sure that another new locomotive/decoder is not on the layout at the same time, else both will move when address 3 is used.
