Chrissaf Posted June 17, 2020 Share Posted June 17, 2020 The 'Function' buttons in RailMaster are only latching if the text on/off appears on the button label..So for example:F0 button should read Lights on/off and not just Lights.F1 button should read Sound on/off and not just Sound..You edit the text on the 'Function' buttons by opening the appropriate locomotive in the 'Locomotive Settings' screen..A fuller explanation of various aspects of using RailMaster are given in these various 'How To' threads (see 8th link down):.Adding a loco from the database into RM (my post 3rd one down).http://www.hornby.com/uk-en/forum/loco-registration/?p=1.Using RM to change the address of an existing Locohttps://www.hornby.com/uk-en/forum/cant-change-loco-cv-address/.Using RM to read and write CVshttps://www.hornby.com/uk-en/forum/problem-with-tts-decoder/?p=1.Manually adding a Loco to the RM Database.https://www.hornby.com/uk-en/forum/r3459tts-decoder-not-recognized-23469/.Full description of the ‘Locomotive Settings’ screen in detail.https://www.hornby.com/uk-en/forum/changing-cruise-and-shunt-speeds/?p=1.Setting up Flying Scotsman TTS Sound Functions.http://www.hornby.com/uk-en/forum/how-to-set-up-default-sound-functions-on-scotsman-r3284tts/?p=1.Expanding the large throttle to see all function buttons.https://www.hornby.com/uk-en/forum/sound-functions-in-rm/?p=1.“on/off” function button labelshttps://www.hornby.com/uk-en/forum/post/view/topic_id/19619/?p=2.Six function button error message.https://www.hornby.com/uk-en/forum/six-function-button-error-post-by-ianb/?p=1/ .TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
Chrissaf Posted June 17, 2020 Share Posted June 17, 2020 Hi Guys, New guy here, just gone the distance and bought an ELink DCC controller and now busy setting it up, manage to understand most of it apart from a problem with function buttons, whatever I program the button to F1, for example, I have the engine on. F0 lights on, both activities work for 3 sec then power off, its as if they work momentarily instead of latching on and staying on, have I not done something right somewhere? don't really want to go back to my select which works fine. Thanks guys Link to comment Share on other sites More sharing options...
ben39uk Posted June 17, 2020 Share Posted June 17, 2020 ChrissafThanks so much , it works Link to comment Share on other sites More sharing options...
Chrissaf Posted June 17, 2020 Share Posted June 17, 2020 😎 Link to comment Share on other sites More sharing options...
