Class 66 cornering issue.
Hello there !
I wonder if anyone has experienced an issue whereby Hornby class 66's slow down to a crawl when running through 3rd and 2nd radius curves, even with only a very short train (3x freightliner flats) . The thing I consider strange is that there's no wheel slip, which might be symptom of flange bite, I tried adding some weight but to no avail.
The locos, I have 2, are both TTS fitted and are both similarly affected.
any advice gratefully received !
Josh
Whilst you wait for a reply, perhaps you would spend a few minutes reviewing the TIPs in the TIP page link below:
There is, as yet unresolved, discussion on another forum relating to TTS-fitted class 47 locos derailing on curves when the motor bogie is the rear bogie.  Apparently no problems experienced when the motor bogie is leading or when running light-engine.  Is your experience the same, albeit with a different class of loco?
