Chrissaf Posted June 22, 2020 Share Posted June 22, 2020 Your loco maybe a victim of a new bug introduced in RailMaster version 1.72 that relates to locomotive speeds..No gaurantee that your loco issue is due to this bug, but in case it is. The documented solution is to completely delete the loco from your RM roster (loco list) and add it again completely from scratch. You might have to do this more than once. If after two attempts and no improvement is observed, then your issue may not be due to this known RM BUG.. Link to comment Share on other sites More sharing options...
Chrissaf Posted June 22, 2020 Share Posted June 22, 2020 Not too sure if I am in the right place if not I apologize I have a class 66 EWS loco that works fine nice turn of speed on my Hornby Select controller. When I swap to my Elink controller it crawls around very very slow I cannot manage to increase its speed I have unticked use scale speeds to no effect, I have reset my CVs to default by inputting 8 to CV8, after reading them and writing them all down, none changed value. Has anyone any idea why this loco is so slow, I have also wound up cruising speed and shunting speed again no effect. Link to comment Share on other sites More sharing options...
