Kevin Hodges Posted June 30, 2020 Share Posted June 30, 2020 Has anyone tried fine cat litter as coal ? I wondering if I could add, pour it to my empty coal wagons, then spray it with 50/50 PVA and water to lock it in ? Then paint it black of course. What do you guys think ? Kev. Link to comment Share on other sites More sharing options...
Chrissaf Posted June 30, 2020 Share Posted June 30, 2020 I'm not a cat owner, but wouldn't adding any moisture to cat litter in the form of 'water/PVA' make the cat litter swell up as part of absorbing the moisture process..Also, not sure what cat litter is actually made from, but if there is any organic components in it, I would expect it to rot overtime, particularly once dampened..Most modellers actually crush up real coal and glue a thin layer over the top of some light weight filling like polystyrene or foam blocks.. Link to comment Share on other sites More sharing options...
Kevin Hodges Posted June 30, 2020 Author Share Posted June 30, 2020 Hi Chris, The litter I use (cat owner) is like course sand. It doesn't swell, but 'clumps'. I know some of the folk who do wargaming scenery sometimes use it for dioramas and basing. Hadn't thought about crushing up real coal. Link to comment Share on other sites More sharing options...
EnGee Posted June 30, 2020 Share Posted June 30, 2020 I used cat litter for track ballasting. I tried a small bit and I have to say the results were rather good. Next time the mrs brought home some more, I nicked a bit of it when the cat wan't looking - then disaster!Not being a connoisseur of cat litter i didn't realize there are 2 types, clumping and non clumping!!Do not use the clumping version, you will end up with a very messy solid lump as soon as you apply any moisture! Non clumping will probably be OK , but try a small bit first. Link to comment Share on other sites More sharing options...
ellocoloco Posted June 30, 2020 Share Posted June 30, 2020 Won't you be encouraging the cat to fill up the wagons with even more load............. Link to comment Share on other sites More sharing options...
JJ73 Posted July 1, 2020 Share Posted July 1, 2020 😆 Very Good Ello - that is what I was thinking!!! 😆 😉 @Engeee :- oppps!!! Link to comment Share on other sites More sharing options...
