81F Posted June 30, 2020 Share Posted June 30, 2020 I have just ordered some Class 33 traction tyres from Hornby, but as the pack of 10 is more than my current need. however I also need a pair for one of my Lima Western Hydraulics. Hwever, before ordering a set will the 33's tyres fit the Western? Many thanks Steve Link to comment Share on other sites More sharing options...
atom3624 Posted June 30, 2020 Share Posted June 30, 2020 Can you measure the tyre dimensions, and that of the Western - should be able to answer your own question. Al. Link to comment Share on other sites More sharing options...
Going Spare Posted June 30, 2020 Share Posted June 30, 2020 Unfortunately, the Hornby class 33 tyres are unlikely to fit a Lima class 52. Although the wheel diameter will be similar, Hornby tyres are almost a square cross-section whereas Lima's are like very thin tap washers before they go on to the wheels. I don't think the Hornby tyres will sit in the Lima wheel grooves properly, leading to running issues/derailments. Link to comment Share on other sites More sharing options...
ColinB Posted June 30, 2020 Share Posted June 30, 2020 I am sure Going Spare is right, I remember I had to order the two different types. Lima ones are totally different to Hornby ones. Link to comment Share on other sites More sharing options...
81F Posted July 1, 2020 Author Share Posted July 1, 2020 Many thanks for the help, I'll order a separate set. Sadly I would have measured the wheels but I had a cateract operation immediately before lockdown and have not been able to get the new glasses they said I would need for close work. However the difference in section suggests that there would be a problem anyway. Link to comment Share on other sites More sharing options...
Jimbo1707820979 Posted July 1, 2020 Share Posted July 1, 2020 Useful to know, Colin. I hate traction tyres and try to avoid or ignore them. I have shed several but it does not seem to make much difference in performance so I have not replaced them so far. Both Hornby and Lima. Link to comment Share on other sites More sharing options...
81F Posted July 1, 2020 Author Share Posted July 1, 2020 The two problems I have is that my Western Pioneer could harly pull the train that it's sisters could. Having turned the loc upside down the only difference I could find was that the tyres were missing. Also one of my deltics runs at full revs but hardly moves along the track. In this caser the tyres have streatched so that the wheels just spin inside them. So I have now ordered both sets. Link to comment Share on other sites More sharing options...
ColinB Posted July 2, 2020 Share Posted July 2, 2020 I have so many issue with traction tyres of my old ringfield based locos and on my Pendelino. They get old and lose traction then you get a horrible squealling noise. The other issue I suspect, is the same one I get with my classic bikes, rubber just doesn't last that long now. On the bikes its shreds after 2 years on the locos it goes hard and stops working. On my Hornby Morning Star it will run for twenty minutes, then the tyres seem to start slipping getting the dreaded squealling noise (no it is not the motor, I checked) and they were new ones. Link to comment Share on other sites More sharing options...
