Chrissaf Posted July 29, 2020 Share Posted July 29, 2020 I assume it has got to be that the Mallard has a four wheeled tender, with the space between the wheels greatly reduced on the tender, as it turns around the curve it shorts. I had a similar issue on my layout with a large radius point and certain Bachmann diesels. What I did was isolate the frog of the point by cutting the links and use one of those autofrog devices, that fixed it. Link to comment Share on other sites More sharing options...
Chrissaf Posted July 29, 2020 Share Posted July 29, 2020 Hi, I have a factory fitted DCC A4 Mallard which will not cross my electrofrog pointsit shorts out at the frog and sometimes I have to re a sign the decoder.all my other locos lincliding the Hogwarts and mauld loco with sound work fine and can cross the points so it must be the locoi have fitted frog wires and insulated joiners as instructed to the point turnoutsany ideas please guys would be appreciated thanks Andy Link to comment Share on other sites More sharing options...
