stephenson rocket R 615
Yelrow
Greetings, i need assistance from any older model rocket owners.  On this model  there are two cylinders, up which the rods move up and down. My RH cylinder, the one with the gold semi circle, on top, is loose, and moves up and down, causing loco, not to move. The other side. is fixed. I need to fix this side, and have no idea, how it locates, etc. Dont want to glue it, if simply, a pin has come adrift. Its part no  6490, for the tech guys.  It is my 77th birthday gift from Heather, and needs to run by Wednesday.   No urgency, but would like a quick response, please. Thanks.
No problem.  😀
If I remember correctly....
The bottom clip is a "C" shape that clips around the boiler location slot.
The top clip has a barb, that really should be eased from inside the boiler moulding, to clear the square hole in the boiler.
To remove, top clip first, then the bottom clip should disengage...
Saharagain, hi, taken out offending side. Pin, is fine, long and round, but the sosket, is kinda diamond shape, bigger than the pin..  First reaction, is to glue it in, but would value your impout. It would appear, no barb, as it came straight out.
