Elite not working
cjb417
You have 'bricked it'. You might possibly be able to recover it yourself, but if you can't, then you will have to send it back to Hornby to have it done for you.
Now it may be that you are trying to follow the very poorly written Hornby update instructions.
I suggest that you work your way through the contents of these two existing previous threads to try and recover the Elite yourself. If after several attempts you are not successful, then your only option is to contact Hornby to arrange them to do it for you.
It is very important that you closely follow each and every documented step to the letter.
Updating Elite firmware [written for Ver1.43 but still the same for current version]
https://www.hornby.com/uk-en/forum/updating-firmware-on-the-elite
Alternative Elite firmware update method if documented method fails [see reply by Peter Rowney].
https://www.hornby.com/uk-en/forum/elite-bricked/?p=2/#post-264669
TIP: As a relatively new poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button.
