go4trains Posted August 8, 2020 Share Posted August 8, 2020 Can anyone help , I am trying to find a way to use the Rocket couplings. They are so small and fiddley that I have so far been defeated in the task. I might get one or even two of them on then desaster they all come appart. Anyone know a quick easy method . Thanks Frank.l off. Link to comment Share on other sites More sharing options...
atom3624 Posted August 8, 2020 Share Posted August 8, 2020 See Sam's Trains - he has a YT channel and had a go at fitting the couplings. Al. Link to comment Share on other sites More sharing options...
Ducky1 Posted August 8, 2020 Share Posted August 8, 2020 I have put mine to one side and have obtained some chain links used for jewelry. The links are 4mm x 2mm. I have cut short lengths and the link just fits over the carriage hook and stays on. They even look more realistic than the plastic ones as the give and take just as they would in real life. Duchy1 Link to comment Share on other sites More sharing options...
JJ73 Posted August 10, 2020 Share Posted August 10, 2020 Yeah I done the same as Ducky above - I went to my Local Model Shop & got some small chains & used them instead - that seemed to work Link to comment Share on other sites More sharing options...
Mac-_- Posted August 10, 2020 Share Posted August 10, 2020 Hmm good idea Ducky, i'll be doing that when i get it up and running again. Link to comment Share on other sites More sharing options...
go4trains Posted June 17, 2021 Author Share Posted June 17, 2021 Thank you all for your help , I think, except for times when I want to " show off " my collection I will keep it in the box. This is because of the linkage problems and the fine detail on the carages (foot plates) are easily damaged. But hey what a great model, and can't wait for the LION ( Titfield Thunderbold). Link to comment Share on other sites More sharing options...
JJ73 Posted June 18, 2021 Share Posted June 18, 2021 Or pratice makes Perfect 😉🚂🚂🚂 Link to comment Share on other sites More sharing options...
dadad Posted July 21, 2021 Share Posted July 21, 2021 Hi there,I bought a length of 9 links to the inch chain from Langly's ( 30 inch lengths) and cut several 9 link lengths to use as couplings. These work fine and are fitted using fine point tweezers and as has been said have a more realistic take up with the first coach moving off with the last one stationary.John Link to comment Share on other sites More sharing options...
