Shed lighting
wizzie
Whatever provides even bright light coverage with virtual elimination of shadows. One reason why professionals use parabolic reflectors for their light sources.
Given that you can get each of those lighting options in various types of light, daylight, warm white, cool, the question then comes back to how long is a piece of string or as Chris said whichever gives even shadow free coverage, added to which is in the type of light hue and colour you prefer.
I would suggest a trip down your local snooker club where the table being lit is as big as your shed. Nowadays they use leds rather than than old filament bulbs.
All of the items in your lists can come in different technical variants, which is why I specified the type of light that would be best, not the product that you select to produce it. It may be that none of the items in your list offer a perfect solution for video work.
Spot and flood lights [if used as a single or even multiple light source] can produce strong shadows. Shadows can be reduced by using diffused light sources. If you watch 'how films are made' type documentaries you will notice that many times, spot / flood lights are located behind large diffuser screens.  Fluorescent tube lighting can potentially produce strobing effects on the final video capture.
It really does depend upon what is the quality you are trying to achieve with your recordings....as to how far you go and how much you invest in your lighting products.
Product Examples
Video Lighting Tutorial
A couple of six ft LAP LED twin bulb strip lights from Screwfix - fitted across the shed at four foot  intervals - you will need sunglasses! Just fitted four in my double width garage - first class. No flicker and instant light. Took me thirty minutes to fit them.
