James Bisley Posted August 14, 2020 Posted August 14, 2020 Recently, I decided to buy a decent gravity airbrush I could use to cover detail parts. I already owned a very good Revell compressor along with Revell hoses, left over from my fathers business. These incedentally fitted fine to a cheap Airfix suction-fed airbrush I had bought.I initially set my heart upon a Badger patriot 105, but after reading comments about how they did not fit to ordinary hoses, went for a Sparmax Max-4 instead. Open delivery, I found that the 1/8" BSP fitting did not connect to my Revell hose.Upon more research and measuring (which should hve been done previously
James Bisley Posted August 14, 2020 Author Posted August 14, 2020 Shucks, is there a word limit? Heres the rest:) I concluded that the larger end of my hose is a 1/4" BSP and the smaller end an unspecified thread with 5mm diameter that apparently is common to Revell and Badger products. So yes, if I had gone for the Patriot after all it would have fitted fine and all would have been well. Such is the life we live.I am posting this partly to share gen and mostly to gain it. Has anyone else had similar compatibility issues? Is 1/8" BSP the standard fitting in the industry or does it vary across all manufacturers? What is this unspecified 5mm connection? Any other helpful info?Thanks very much!!!!
peebeep Posted August 14, 2020 Posted August 14, 2020 I think the airbrush end of Badger stuff is unique to them and it's Badger that supplies the Revell equipment. Everybody else uses 1/8 or 1/4 in my experience. You can get a set of universal adaptors for under a tenner, posted off of Ebay.
James Bisley Posted August 14, 2020 Author Posted August 14, 2020 Ah! That explains it all. Thanks for the gen.I've just bought a single £5 adaptor from everythingairbrush.
