R1019 Tender Driven A1 Wheel Slip
Mathmonkey77
Hello, my Flying Scotsman (tender-driven) has loco wheel slip. The train moves and the tender wheels work fine (to my knowledge) but the dummy drive wheels under the loco turn a little bit, stop, then slide across the rest of the track. It still works, just doesn't look very realistic. If I apply pressure to the middle of the loco chassis, the drive wheels will turn properly.
This locomotive is from the R1019 Hornby Flying Scotsman Train Set (I think from the 1990's), if that helps.
Many Thanks,
mathmonkey77
I would check a few things:
  1. Check the alignment of the coupling and connecting rods - is there any point where they 'clash' / interfere and block the movement?
  2. Once you've check the rods, then how freely do the main drivers - non-driven - move side-to-side? This could be an indication that a good clean is required of the axles and a spot of lubrication.
Never 'drown' the locomotive in oil - it always ends up on the rails and adds to problems!!
Al.
Often the valve gear or connecting rods get slightly squeezed inwards (either from handling the loco or when stored/in the post if bought unboxed), and catch against each other or against the coupling rods.  Sometimes very gently easing the slide bars (attached to the cylinders) outwards can help this, but the emphasis is on "gently".
Hello all!
I followed your advice, and while I was reattaching the shell to the chassie after cleaning and oiling, I discovered that the back driving wheels were slightly higher than the rest. After adding some weight under where the whistles are and slightly adjusting the tightness of the screw that holds the back bogie on, the locomotive works as perfect as can be! Thanks again!
P.S. For those curious, I used an old AA battery taped to 2 heavy nuts for the weight
Hello all!
Don't leave the batteries in the loco.  They will eventually corrode and leak, probably causing the loco to rot away where the contents of the batteries leak out.
