philandsue Posted August 25, 2020 Share Posted August 25, 2020 Following instructions on Elite controller i set the accelation on my loco - set to 60. that now seems very slow but seem unable to change it to any other value. Link to comment Share on other sites More sharing options...
96RAF Posted August 25, 2020 Share Posted August 25, 2020 Can you read the decoder address with your Elite - this will prove the programming dide is working. You can change accel value either in the menu for accel or by writing directly to CV 3. If this doesn’t work ... Reset the decoder by writing value 8 to CV8 (most decoder makes). This will put accel and decell back to value 5 and also address will be given value 03. Link to comment Share on other sites More sharing options...
Chrissaf Posted August 25, 2020 Share Posted August 25, 2020 As you have an Elite. You can 'factory reset' the decoder and start again. How to 'factory reset' a decoder using the Elite controller was documented yesterday in another thread..https://www.hornby.com/uk-en/forum/decoder-reset-using-the-elite/?p=1.Unable to make the link clickable at present due to the forum BUG. Copy and Paste the URL text manually into your browser..EDIT: Rob beat me to the draw. You can also use the basic CV writing technique described in my linked thread above to write the value you want directly to CV3 as Rob suggests. Link to comment Share on other sites More sharing options...
philandsue Posted August 25, 2020 Author Share Posted August 25, 2020 Sorry, my mistake - it is of course a 'select' not elite. which is going off tomorow all being well for firmware update. Link to comment Share on other sites More sharing options...
96RAF Posted August 25, 2020 Share Posted August 25, 2020 I never cease to be amazed how many posters have led us down the garden path of confusing Elite with Select and eLink.In future my first response will be - post a photo of it, or how many knobs does it have. Link to comment Share on other sites More sharing options...
philandsue Posted August 25, 2020 Author Share Posted August 25, 2020 Very sorry to cause you any problems.Thanks for your help. Link to comment Share on other sites More sharing options...
96RAF Posted August 25, 2020 Share Posted August 25, 2020 Its not you, its a universal problem. Link to comment Share on other sites More sharing options...
philandsue Posted September 17, 2020 Author Share Posted September 17, 2020 I have now received my SELECT controller back from Hornby having had the firmware updated. Maude now runs fine - address 03. The 0-6-0 loco that I originally had as 03 now runs as 01. This loco was the one i set up an acceleration value for which now seems to be very slow. Am I correct in thinkibng I can change this but must use a CV address - which was not available, so not any experience yet, on my original select version. Thanks for your help Link to comment Share on other sites More sharing options...
96RAF Posted September 17, 2020 Share Posted September 17, 2020 You can change the accel level using your updated Select either via the normal menu method or via a direct input value to CV3. Please see the v1.5 manual and v1.6 addendum downloadable from the main site Downloads area. Simply resetting the decoder will apply a default accel level of value 5. Link to comment Share on other sites More sharing options...
