Blueandwhiteton Posted August 25, 2020 Share Posted August 25, 2020 Hello all, I am servicing my hst ringfield motor but there is no continuity between chassis and the coils on the commutater could it be a broken wire ?, or is the magnet demagnetised I am at a loss, unfortunately I have assembled my other cleaned motor into my other power car, thanks for any info. Link to comment Share on other sites More sharing options...
STG Posted August 25, 2020 Share Posted August 25, 2020 You should find two sets of springs and carbon brushes making contact between the commutator and electrical contacts on the outside of the motor, surely... There are plenty of tutorials for servicing these motors online, they will probably be helpful for your case. Link to comment Share on other sites More sharing options...
Blueandwhiteton Posted August 25, 2020 Author Share Posted August 25, 2020 Thank you STG, I stripped comm out of holder and there was a broken miniscule wire from one coil which when tested with my meter rings out through chassis but I can't see a place that would indicate where the wire was soldered onto, am I right in assuming that this cannot be repaired and a new comm assembly will have to be sourced on an well known auction site. Link to comment Share on other sites More sharing options...
STG Posted August 26, 2020 Share Posted August 26, 2020 If the ringfield motor doesn't work anymore you have 3 main options:Using relateable web images, find where the wire could goJust get the required new parts of the motor (could be quite expensive)Convert the Ringfield to a CD/DVD Motor Link to comment Share on other sites More sharing options...
96RAF Posted August 26, 2020 Share Posted August 26, 2020 Can’t post a picture due to this forum bug but I will try to describe the fix. Enamelled wire is attached to the tab of one commutator segment, this wire winds round one pole piece and connects to the next tab, then goes on to coil round the next pole piece, connects to the third tab, then coils around the last pole piece and finally connects to the very first tab. This decribes a three pole motor but a five pole motor just has more coils and tabs. In your case you may be able to resolder the loose wire to the associated tab. If not a new ringfield armature is not expensive. See Peters Spares or New Modellers Shop for the correct one for your motor. Link to comment Share on other sites More sharing options...
ColinB Posted August 26, 2020 Share Posted August 26, 2020 I did manage to fix one of mine after someone on this site told me what to look for. Alternatively, you can buy a rewound one off EBay, you send them your old one and they send you a rewound one or alternately Lendons of Cardiff have ones at £12.99 which is the route I eventually took. They even have "sleeved" five pole ones, buy they are very expensive. Link to comment Share on other sites More sharing options...
The son of Triangman Posted August 26, 2020 Share Posted August 26, 2020 If you can't fix it, Scalespeed rewind armatures and remagnetise them. Link to comment Share on other sites More sharing options...
96RAF Posted August 26, 2020 Share Posted August 26, 2020 Out of stock here but cheap enough.Scroll down almost to the very bottom of the page.https://www.newmodellersshop.co.uk/hornby_spares_motors_and_gears. ditto Peters Spareshttps://www.petersspares.com/index.jsp?searchStr=Armature Copy and paste into your browser as usual . Link to comment Share on other sites More sharing options...
