Reddington Posted August 28, 2020 Share Posted August 28, 2020 Good Morning Everyone, My Daughter and I finished assembling the suspension bridge and later today we will be fitting it our layout.My questions are should the bridge be glued down ? Can I use track screws to lay the track onto the bridge ? Thanks in advanceRed. Link to comment Share on other sites More sharing options...
Flashbang Posted August 28, 2020 Share Posted August 28, 2020 HiI wouldn't screw or pin anything! Consider using "Tacky Wax" this holds items very securely and is easy to reposition or remove items later on without any damage. Its also great for holding those little people in place too on pavements and platforms etc 😆 Link to comment Share on other sites More sharing options...
Buz Posted August 28, 2020 Share Posted August 28, 2020 Hi ReddingtonIf it is like the Triang bridge it will have slots in the base of the bridge piers so it can be screwed downThe bridge needs to be held in place if on a permanent layout.Flashbang' idea of a little tacky wax is a good ideas I would not fix the track to the deck if you don't need to, the track slot should hold it in place if its not going to be moved.If it's the bridge I think it is at 4' long that's going to be a very dominant feature on the layout.regards John Link to comment Share on other sites More sharing options...
JJ73 Posted August 28, 2020 Share Posted August 28, 2020 No - don't track screws on to the bridge - you could brake the bride - I just lay the track on my 2 suspension bridges!!! Link to comment Share on other sites More sharing options...
Reddington Posted August 29, 2020 Author Share Posted August 29, 2020 Thanks for the reply’s Red Link to comment Share on other sites More sharing options...
