Posted
I bought sunset speedway set first lane change worked well. After few minutes when I pressed lane change button on wireless controller it stops the car when I release accelerate again. What do I need to fix it. Track seems work when I position the lane to change and push the car manually over the sensor flipper flips back to straight position. But some kind of setting issue that I am missing? Help me fix please.
Posted
Hi Dr.mario - welcome to the forum!
There are two buttons on the top of the ARC controller - the lane change button (with a 'Y' on it) is above the brake button (with the 'X'). Maybe you are pressing the wrong button? What you describe is what the brake button does.
It is a very good idea to keep the ARC Pro Quick Start Guide handy as you are getting to grips with the new system - there's a lot to learn and remember. When you start to look at using the ARC app, I've written this guide: slotracer.online/arc-pro-guide
I hope that helps!
Posted
If you are not pressing the wrong button it could be the plate where the contacts are has been swapped around.
If pushing the "brake" button causes a lane change then that must be the case...
