Posted
My Hornby APT has been in storage for 35+ years and I'm now in the process of restoring it and upgrading it for DCC.
The pantograph is missing its spring.  I've ordered some Hornby X8114 (M1544) springs as I read these were the most suitable and could be adapted to fit.
However, I can't find anything that explains how to adapt it, nor do I know what the spring position and setup would be on a working pantograph.
Could someone post some pictures of a pantograph with its original spring and if possible some instructions on how to convert the replacement spring to fit?
Thanks!!
Posted
/media/tinymce_upload/221ade77d44880fe7e94577a4f588af4.jpg
Just found this on a quick search - you can see the spring quite clearly so I hope this should shed some light on where it should attach.
Posted
The pantograph on the APT is the same as the one Hornby used on their class 86 but with a different Base. You can probably find some photos of a Hornby class 86 online Unless someone with instant posting rights can put one up?
Posted
Thanks Rana, I found a photo of the Class 86 pantograph.  I realised that on my APT pantograph the shiny bar running up the back had been put in the wrong way up, hence why I couldn't see where a spring should attach.  Once the X8114 springs arrive I'll have a go at customising one to fit.  Looks like it could be tricky!
Posted
Thanks for the tips, I managed to fit a X8114 spring and the pantograph stands up quite nicely.
I don't know how you get it to stay down.  Either it clips somehow and I'm not doing it right or perhaps the spring is too strong??
/media/tinymce_upload/31d9131fb287441862234e5f5a2f594a.jpg
