Chrissaf Posted September 16, 2020 Share Posted September 16, 2020 I've just bought a new class 43 HST and having abit of trouble with the lights, I can't change the dummy car's lights from white to red. The powered car is ok. I would be grateful for any suggestions as I would like to run the train with the dummy car at the end so would like a red light. Is it to do with the direction of travel in relationship with the Select controller because I cannot change the direction either. How many white lights should there be - 3 or 4 on each car? Link to comment Share on other sites More sharing options...
96RAF Posted September 17, 2020 Share Posted September 17, 2020 Sounds like a wiring fault in the powered car. If under warranty I would send it back. If not under warranty then I would be looking for solder bridging problems on the pcb that has the decoder socket or a misllaced wire to the lights. Link to comment Share on other sites More sharing options...
ColinB Posted September 23, 2020 Share Posted September 23, 2020 I think the issue with this, is there are multiple types of HST, not helped by Hornby. The newer Railroad HST from what I gather from posts (my one is old and I had to add DCC sockets) has the lights on permanently, so I think that explains many of the issues. You can do what ever you want to the decoder, but it is not going to change that. What you need to do is rewire the DCC socket so they are controlled by the decoder. I think it would help a lot if people explained what level of HST they have. Link to comment Share on other sites More sharing options...
