AVFCAM Posted April 29, 2012 Share Posted April 29, 2012 I'm sorry if this is a stupid question, or if it has been asked before, but I can't seem to get a straight answer...Can I use a Hornby accessory decoder with Seep point motors? The Seep motors will suit my layout more as they require a smaller amount of space than the other motors I have seen...but, I want my points to be digital, so if they are not compatible then I can't use them.Also, do points need to have switches etc when being controlled digitally? Link to comment Share on other sites More sharing options...
Flashbang Posted April 29, 2012 Share Posted April 29, 2012 HiThe Hornby points decoder can indeed work Seep motors. If its the R8247 then all you need to ensure is that the output is set to 'pulse' (which it is by default).You don't have point operation switches/levers or a CDU when a Hornby point decoder is used. Link to comment Share on other sites More sharing options...
AVFCAM Posted April 29, 2012 Author Share Posted April 29, 2012 Cheers mateStressing about all the wiring that's needed...but I guess that it is easier as no switch is there. Link to comment Share on other sites More sharing options...
