JsionyRN Posted September 27, 2020 Share Posted September 27, 2020 Good eveningis it possible to use a Hornby R406 colour light signal with a gauge master prodigy 2 advanced controllerregards jsionyRN Link to comment Share on other sites More sharing options...
Chrissaf Posted September 27, 2020 Share Posted September 27, 2020 You need to interface the R406 signal with an Accessory Decoder that has the following capability. Firstly, the decoder output needs to be 3 wire (like those used for Solenoid point motors).Secondly, you need an Accessory Decoder that can be configured for an 'always on' output. Meet these two above requirement criteria with an Accessory Decoder that can be controlled by a GM Prodigy Advance 2 and you are all set to go. Link to comment Share on other sites More sharing options...
