Chrissaf Posted September 30, 2020 Share Posted September 30, 2020 You'll find all the information here..... https://www.hornby.com/uk-en/hornby-track-planner .......HB Link to comment Share on other sites More sharing options...
Chrissaf Posted September 30, 2020 Share Posted September 30, 2020 Can anybody help me with the part numbers for the track thinking of building a track from the hornby track plans thank you Link to comment Share on other sites More sharing options...
Chrissaf Posted September 30, 2020 Share Posted September 30, 2020 Be aware that the linked track information area is for the current [modern] Nickle Silver track. If your track plan book is of vintage era, then the plans would have been created when track was steel not Nickle Silver. These old plans might also have deployed gradients [the steel track was compatible with locos with Magnahesion that is now an obsolete technology] and won't suit modern light weight low powered locomotives. These old track plans might also make extensive use of Radius 1 curves, again these won't suit modern long wheelbase rolling stock. So, by all means build a layout from a track plan book, but be aware that even more recent books may still contain some of these unsuitable plans in them. Unsuitable, as in not being suitable for modern rolling stock products. PS - Track plan books usually give an inventory of the track parts as part of the plan. If the R numbers in the plans don't match the R numbers given on the linked page, then the plan is ancient and designed around track parts that are now obsolete. TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
