Chrissaf Posted October 8, 2020 Share Posted October 8, 2020 I have a Hornby class BR 37 Diesel that i would like to convert to dcc. Trouble is it only has one wire connected at one end to the bogie via a metal plate above the bogies and the other end is connected to the motor. Can anyone help? Link to comment Share on other sites More sharing options...
Going Spare Posted October 8, 2020 Share Posted October 8, 2020 With only one wire running from the non-powered bogie to the drive bogie, it is likely to be a Ringfield motor so you need to identify which type of Ringfield motor it is and follow the conversion procedure outlined by Brian Lambert as per the previous post. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 8, 2020 Share Posted October 8, 2020 Scroll down the page that opens on the link below to the Ringfield motor section.https://www.brian-lambert.co.uk/DCC-Page-1.html#decoderinstalation TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
