Skipper61 Posted October 22, 2020 Share Posted October 22, 2020 Hi, can any one explain how you set up Dapol semaphore signals using Train-Tech decoder.I am thinking of putting Dapol semaphore signal 4L-001-003 on to my layout and using a Train-Tech decoder SC3 to operate it. My problem is when I put a signal onto my layout plan and try to select a decoder type in the settings box there is not a Train -Tech decoder listed for the SC3.Do I use one of the other two Train-Tech decoders listed, either Train-Tech Colour Light Signals or Train-Tech-4port decoder. I am using Rail Master Pro 1.72 Any advise would be appreciated. Thanks. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 22, 2020 Share Posted October 22, 2020 I have previously written a post documenting a full 'step by step' tutorial for setting up the Train-Tech SC3 decoder and integrating it into RailMaster. Searching the forum for the term SC3 would have found it [2nd result in the search results list]. But to save you time, here is a direct clickable link. Train Tech SC3 decoder used with Dapol Semaphore signals (RailMaster)https://www.hornby.com/uk-en/forum/train-tech-sc3/?p=1 My problem is when I put a signal onto my layout plan and try to select a decoder type in the settings box there is not a Train-Tech decoder listed for the SC3. The thread on the link above has a later post from the original question poster that my written tutorial guidance worked like a charm. My tutorial recommends selecting the Hornby R8247 decoder in the 'settings box'. Also note the two replies on the page from Train-Tech themselves confirming my guidance [5th post down and the last post on the page]. Link to comment Share on other sites More sharing options...
Skipper61 Posted October 22, 2020 Author Share Posted October 22, 2020 Hi Chris,Thanks for your help. That has resolved my problem. I will now purchase some signals and decoders and have a go, now that I can see the proceedure. Thanks for your help.Regards Graham. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 22, 2020 Share Posted October 22, 2020 😎 Link to comment Share on other sites More sharing options...
