frazzle Posted May 20, 2012 Author Share Posted May 20, 2012 Post a new reply... Link to comment Share on other sites More sharing options...
frazzle Posted May 20, 2012 Author Share Posted May 20, 2012 OP here, sorry for my lack of previous responses to the questions asked, ive been away :)So, BEMF, i checked CV10 and it was set at 255, so i dropped this to 125....no difference.I checked the speed tables, set cv29....nothing. I changed the decoder to a different brand, perfect!!!!! back to needing to slow it down for scale speedMaybe the Le*z decoders run slower? or maybe my one is slightly faulty? Would never had noticed had the loco not been a DP1 Deltic which i wanted to set to 110 mph top speed.Very interested to read others comments, you guys certainly know your stuffFrazzle Link to comment Share on other sites More sharing options...
hosh Posted May 21, 2012 Share Posted May 21, 2012 It seems impossible to beleive that any decoder could or would be unable to allow the track power right thru to the motor (other than changing it to DC of course - I wonder if that's somehow where the problem is?).Just wondering, did you change CV10 first or enable the speed table via CV29? And did you change CV10 back before you enabled CV29 (or vice versa)? If so, then the slow factory setting for the top speed step was in play, even though bemf was off (maybe).Furthermore, and probably more importantly, I mentioned CV10 because it is the CV suggested on the wiki page. A look through a few L*nz PDFs (and other manufacturers) showed that they use other CVs for bemf so I'd be checking that in the decoder's manual.If CV10 was for bemf, I doubt it'd be set to 255 by default so.............. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 21, 2012 Share Posted May 21, 2012 You might also note my post on a related thread:I also found this post from Phil_Spiegel which I'm sure will interest you concerning speed tables and setting max speed. He says you can do it:IFF (If and only IF) the DECODER fitted supports it: CV5 is top speed, and the alternative supported by some (higher spec) decoders is to define your own speed table.The CHEAP Hornby Decoder does NOT support CV5 ( which I find VERY surprising since experience shows it to be the most important CV - essential for young children too)The SAPHIRE DECODER supports CV5 AND the alternative option of your own custom speed table.FACTORY FITTED locos: SOUND fitted locos use ESU Loksound Decoders, and support bothCV5 and the custom speed table.SILENT_PRE_FITTED locos .... 'anyones guess' ... which is why many people prefer not to buy pre-fitted: Eg The Pendolino used a 'unique' decoder, at least on initial release. I believe later locos might use the basic decoder ,,, ie no CV5Report Link to comment Share on other sites More sharing options...
