RayWood Posted November 27, 2020 Share Posted November 27, 2020 I have a Scalextric set from circa 1995 with 2 RS Cosworth cars. One of the cars works fine but the other only moves a couple of inches on the track before stopping. On investigation the motor contines to whir but the drive shaft stops turning after a couple of rotations. So I'm guessing that I need to replace the motor. I'm very new to doing maintenance of these cars so not sure what motor I need or the best place to get it from. Not being a modeller I want to keep it as simple as possible i.e. preferably no soldering although if that is only way then OK with doing that. Thanks in advance for any advice. Link to comment Share on other sites More sharing options...
